    What is an oil-water heat exchanger and how does it work in a Porsche?
    Plate heat exchangers, as installed in our Porsche, belong to the group of oil coolers.
    They have now been used very successfully for many years in the entire range of the Porsche series, whether in Porsche sports cars or in thoroughbred racing cars with absolute top performance.
    The main task of such a heat exchanger is to use a plate system made of conductive aluminum to separate the oil and water circuits from one another, but at the same time to connect them so closely that the different media can exchange heat with one another and thus regulate them very well.
    Depending on the number and size of the individual plates installed in the heat exchanger system,
    the heating output, but also the cooling output, is regulated when the engine is running at full load.
    A plate heat exchanger is used in a Porsche engine because sufficient cooling water is available there and because oil cooling using cooling water and a heat exchanger is the most efficient variant of an oil cooler on a Porsche car.
    In newer Porsche vehicles, oil-water heat exchangers are used in engines, but also in the gearboxes of the GT variants.
    In top-class racing vehicles, the heat exchangers are about twice as large as in production vehicles. This is because the temperature differences between oil and water are much greater during operation and have to be regulated by the heat exchanger.
    During cold running, the cooling water is heated up faster than the engine oil.
    The heat exchanger ensures that the cooling water, which warms up more quickly, heats up the oil much faster than without a heat exchanger.
    At full throttle, in a racing car for example, the engine oil usually gets much hotter than the cooling water. Here the heat exchanger again ensures a very good heat balance between the two media and a very good cooling of the engine oil.
    Even with short-term peak performance, the engine oil heats up, especially in the areas in the engine where there is a lot of friction, such as the bearings and at the pistons and cylinders. Here the heat exchanger ensures very good cooling.
    An oil temperature indicator is not used in newer Porsche vehicles, because the temperature difference
    between the cooling water and the engine oil is only slightly different during normal operation of the vehicle.
    I'm happy to answer any questions
    master mechanic for Porsche
    Team Albert Motorsport
    Dear all,
    we've been on the market since 1974 and consistently rebuild Porsche engines and transmissions.
    From time to time it happens that our customers have commissioned their work elsewhere.
    Often, even very often, we see exactly these customers again almost six months later
    with us, in order to then have the "presumably too expensive repair" carried out by us.
    In the following case it was the same - but why do you think?
    See what we have received for repair:
    As always, we gave this customer a rough budget for repairing his Porsche 997 engine damage.
    It was also the well-known piston and cylinder damage on a Porsche 911, type 997 Carrera, generation 1 with 320 hp.
    We had this #damage repair on the part of the costs
    at KV delivery, specified with roughly 15 thousand euros.
    That was far too expensive for our customer, as he told us.
    He then gave his acquaintance, a "freelance workshop man from Cologne", the engine repair order.
    The first call from the customer came after 3 months: "Mr. Albert, how long does an engine repair like this actually take for you"?
    My answer: "On average and depending on our workload and the material supply, between 2 and a maximum of 6 weeks"!
    "OK, I'll get back to you then," he said.
    "Okay, if you have any questions, you're welcome," was my reply.
    3 months later: "Mr. Albert, what would it cost me if you repaired my #Porsche #engine after all? But we have already taken the engine apart and my workshop man apparently cannot find the damage, and he also gets the block not apart he probably lacks the special tool and he has obviously overestimated himself completely and he probably doesn't have any more time at the moment and whatever" .......
    I: "Ok, then bring the car over to us, we'll take a close look at everything again and then give you a new cost estimate, under the new ( "presumably more favorable") conditions" .... Because, yes, it was me known, the engine has already been removed and disassembled, and so at least these costs are unnecessary ... that's what I thought to myself.
    I'll make it short:
    The customer drives to Cologne, pays 2,500 euros for disassembly and finds his defective engine as "bulk goods". Everything, really every little part, was thrown into a big heap and simply "shoveled" into the customer's Ford Transit when he picked it up.
    At this point I will save myself an evaluation of the workshop man,
    because our customer has already done that extensively in advance.
    The fact is: As a result, our customer had to shoulder a significantly higher block of costs than we had advised him in advance. Much of the material removed was deformed and damaged during removal, making it unusable.
    Apart from the many missing parts, we also had an enormous effort to first clean and sift everything in order to then laboriously find out what exactly is missing and what we had to replace and get in detail.
    In the end we put everything back together properly and handed it over to the customer
    delivered his car again after a #repair period of around 4 weeks.
    1. I would like to give some advice here in the event of engine damage,
    2. so that you don't fall flat on your face like our customer unfortunately did too:
    3. Take a close look at the company you entrust your technology to.
    4. Analyze the reputation and ratings of the company in the market.
    5. Is the repair shop a master car workshop from the Chamber of Crafts?
    6. What about in the event of damage, do you get a 24-month guarantee?
    7. Do you get a proper invoice as proof of the repair?
    8. Do you get a written repair documentation and also with pictures?
    9. Are original Porsche parts used, or are cheap China parts used?
    10. Can you watch everything that is happening to your engine at work without having to register?
    11. Are there reputations from people who have already had engine damage repaired there?
    AN IMPORTANT QUESTION IS:
    How and according to which repair method should your engine be repaired there?
    Ask for it explicitly, because that will decide how long the future engine life will be.
    HERE you will find some lines how we #solid and #durable
    Carry out #repairs on #Porsche #Wasserboxer #motors!
    If you have any questions, I'll be happy to answer them.
    Many greetings
    soeben erhalte ich eine Information zu einer Rückrufaktion vom Kraftfahrtbundesamt:
    Das KBA warnt vor möglicherweise defekten Alurädern.
    Gewarnt wird vor der Verwendung der Sonderräder des Herstellers Esseruote vom Typ Scuderia 1775.
    Wie das #Kraftfahrt #Bundesamt (#KBA) mitteilt, kann es an #Sonderrädern des #Radtyps #Scuderia #1775 zu strukturellen #Brüchen der #Speichen kommen, die im #Fahrbetrieb zum Verlust der #Kontrolle über das #Fahrzeug führen können.
    Die Sonderräder entsprechen nicht den #Vorschriften der #StVZO, die #Betriebsfestigkeit der Sonderräder ist nicht gewährleistet.
    Die betroffenen #Leichtmetallfelgen sind an der genannten #Bezeichnung sowie der eingegossenen #KBA-Genehmigungsnummer #53204 zu erkennen.
    Die Sonderräder des #italienischen #Herstellers werden seit 2019 gefertigt und vertrieben.
    Es kann nicht ausgeschlossen werden, dass die Sonderräder auch nach Deutschland eingeführt
    wurden. Besitzer dieser Sonderräder werden aufgefordert, diese nicht weiter zu verwenden.
    ein weiterer Fall für unser Porsche Kuriositätenkabinett:
    Hier hat ein technisch besonders versierter Zeitgenosse die ideale Lösung gefunden, um eine Porsche 911 Nockenwelle gegen Diebstahl zu schützen.
    Auch erwartet er wohl, dass sich diese Welle nicht mehr von allein lösen wird.
    Stopp, da liegt ein Denkfehler vor ....
    Aber warum denn?
    Er hat versäumt vorher eine #Materialprüfung an der #Nockenwelle und dem #Kettenrad vorzunehmen, denn dann hätte er festgestellt, dass diese alte 911 er Nockenwelle aus #Gusseisen und das Kettenrad aus #Stahl sind.
    Die Konsequenz aus diesem Verschweißen ist die, dass aufgrund der differenten #Gefügestrukturen der verbundenen #Materialien, die Nockenwelle unmittelbar hinter der #Schweißnaht abbrechen wird.
    HIER ein paar Zeilen zu Nockenwellen aus #Stahl und #Gusseisen.
    an Motortechnik interessierte Personen kennen den Begriff: "#Nockenwellen", und wissen,
    dass #Nockenwellen für die #Motorsteuerung eines 4 Takt #Ottomotors unabdingbar sind.
    Aus welchem Material werden Nockenwellen gefertigt?
    Nockenwellen im PKW und LKW werden entweder aus Stahl oder aus Gusseisen hergestellt.
    Das Ausgangsprodukt der Stahlnockenwellen ist meist ein geschmiedetes oder gewalztes Stangenmaterial, das anschließend genau bearbeitet und an der Oberfläche induktionsgehärtet bzw. zementiert wird.
    Nockenwellen aus gehärtetem Gusseisen werden durch das Gießen von Eisenlegierungen hergestellt. Das bei Guss-Nockwenwellen verwendete Material unterscheidet sich durch die Materialstruktur. Primär ist im Gussmaterial ein höherer Anteil von Kohlenstoff mit maximal 2,11%. vorhanden.
    Nockenwellen aus Stahl und Gusseisen unterscheiden sich im Strukturaufbau, und zwar durch die differente Anordnung der Atome in den Kristallgittern.
    Im Gegensatz zu Stahl lässt sich #Gusseisen aufgrund seines hohen #Kohlenstoffgehaltes nicht verformen und schmieden. Es ist auch nicht magnetisch, da dazu die Atome des Materials in die gleiche Richtung ausgerichtet sein müssen. Gusseisen bildet keine polarisierte Masse, die sich ausrichten kann.
    Stahl-Nockenwellen vertragen größere mechanische Beanspruchungen als Wellen aus Gusseisen.
    Nockenwellen aus gehärtetem Gusseisen haben härtere Oberflächen, die Herstellung ist einfacher und preiswerter z.B. für den Aftermarket.
    Bei der Materialwahl stehen meist die einzuhaltenden Kosten im Vordergrund.
    Bei #Hochleistungsmotoren kommen meist hohlgebohrte #Stahlnockenwellen zu Einsatz.
    The new Porsche 911 Turbo S rounds out the boxer engine family. The newcomer, equipped with two VTG turbochargers, joins a long and illustrious pantheon of predecessors. It embodies the passion and emotion, acumen and expertise of over seventy years of sports car design.
    911 Turbo S: Fuel consumption combined 11.1 l/100 km; CO₂ emissions 254 g/km
    The genetic codes of all of Porsche’s current boxer engines are 9A2 and 9A2 evo for four- and six-cylinder engines. They represent a flexible system of identical, technically similar, and individual components that together form a proven foundation, yet also create the space for a plethora of different character traits. A glance at the range of options amply demonstrates the point: four or six cylinders, naturally aspirated engine or turbo, between two and four liters of displacement, from 250 to 640 hp (911 Turbo S: Fuel consumption combined 11.1 l/100 km; CO2 emissions 254 g/km) of power, and torques between 310 and 800 Nm.
    One thing that all members of the boxer family have in common is their cylinder spacing: invariably 118 millimeters. Within the cylinders, pistons with diameters of 91 and 102 millimeters do their duty. More precisely: either 76.4 millimeters up and down or 81.5, depending on the crankshaft. Together with the number of cylinders, this results in five different displacements and nine power levels in the 718 and 911 model lines. With a pool of identical parts that are used without modification in all model lines, as well as components with similar design principles, the result is a wealth of synergies in the fundamental engine design toolbox. This enables developers to concentrate on the individual character of the engine’s periphery—for instance, the intake duct and exhaust system. The result is typical Porsche: because all boxer engines bear the same genes and despite their different characters, they’re all equally efficient, emotional, and driven to perform.
    Performance
    The new turbo engine delivers astonishing power. The key: enhanced turbochargers with variable turbine geometry (VTG) and wastegates as well as the redesigned, more efficient conveyance of process and charge air.
    Efficiency
    The optimization of internal friction in the engine and a redeveloped combustion process with centrally positioned piezo injectors enable both greater power and improved efficiency.
    Emotion
    Whether four cylinders or six, a naturally aspirated engine or turbo: what all Porsche boxer engines have in common is the characteristic sound, the high revving capacity, exceptional responsiveness, and a low center of gravity for maximum driving pleasure.
    Info
    Text first published in the Porsche customer magazine Christophorus, No. 394.
    Text by Thorsten Elbrigmann
    Illustration by design hoch drei
    Der neue Porsche 911 Turbo S macht die Boxermotorenfamilie komplett. Das von zwei VTG-Turbos aufgeladene Aggregat krönt eine lange und illustre Ahnengalerie: Es vereint Leidenschaft und Emotion, Akribie und Expertise aus über 70 Jahren Sportmotorenbau.
    911 Turbo S: Kraftstoffverbrauch kombiniert 11,1 l/100 km; CO₂-Emission 254 g/km
    Die genetischen Codes aller aktuellen Boxermotoren von Porsche lauten 9A2 und 9A2 evo für Vier- und für Sechszylinder. Sie stehen für ein flexibles System aus gleichen, konstruktiv ähnlichen und individuellen Teilen, die gemeinsam eine erprobte Basis bilden und zugleich Raum schaffen für ein Höchstmaß unterschiedlicher Charakterausprägungen. Das zeigt schon der Blick auf die Bandbreite der Möglichkeiten: vier oder sechs Zylinder, Saugmotor oder Turbo, zwischen zwei und vier Litern Hubraum, von 250 bis zu 650 PS (911 Turbo S: Kraftstoffverbrauch kombiniert 11,1 l/100 km; CO2-Emission 254 g/km) Leistung bei Drehmomenten von 310 bis 800 Nm.
    Was alle Mitglieder der Boxerfamilie verbindet, ist unter anderem ihr Zylinderabstand: immer 118 Millimeter. In den Zylindern laufen Kolben mit 91 oder 102 Millimeter Durchmesser auf und ab. Genauer: entweder 76,4 Millimeter auf und ab oder 81,5 – je nach Kurbelwelle. Daraus und aus der Zylinderanzahl ergeben sich fünf verschiedene Hubräume und neun Leistungsstufen in den Modellreihen 718 und 911. Durch einen gewissen Pool an Gleichteilen, die in allen Baureihen unverändert Verwendung finden, und Komponenten mit ähnlichen Konstruktionsprinzipien ergibt sich ein hoher Synergieeinsatz im Grundmotorbaukasten. Er ermöglicht den Entwicklern, sich auf die erforderliche Individualität der Motorperipherie zu konzentrieren – zum Beispiel auf Ansaugtrakt und Abgassystem. Das Ergebnis ist typisch Porsche: Weil alle Boxermotoren die gleichen Gene in sich tragen, sind sie trotz ihrer unterschiedlichen Charaktere alle gleichermaßen performant, effizient und emotional.
    Performance
    Der neue Turbomotor beeindruckt mit überlegener Kraftentfaltung. Der Schlüssel hierzu: weiterentwickelte Lader mit variabler Turbinengeometrie (VTG) und Wastegates sowie die neu gestaltete, effizientere Führung von Prozess- und Ladeluft.
    Effizienz
    Vor allem die Optimierung der innermotorischen Reibung und ein weiterentwickeltes Brennverfahren mit jetzt zentral angeordneten Piezo-Injektoren tragen zur Mehrleistung und Effizienzsteigerung bei.
    Emotion
    Ob als Vier- oder Sechszylinder, ob als Saugmotor oder als Turbo: allen Porsche-Boxermotoren gemeinsam sind der charakteristische Sound, die hohe Drehfreude, das spontane Ansprechverhalten und der niedrige Schwerpunkt für maximalen Fahrspaß.
    Info:
    Text erstmalig erschienen im Porsche-Kundenmagazin Christophorus, Nr. 394
    Text: Thorsten Elbrigmann
    Illustration: design hoch drei
    das was heutzutage in Deutschland und Europa in Sachen Transparenz, Offenheit und Wahrhaftigkeit passiert, ist völlig unerträglich und unser Land und Europas Bürger leben als wäre nichts gewesen in Ruhe weiter ....
    Ein massiver #Sabotageakt zerstört die Hauptschlagader der Energieversorgung unseres Landes. Der Wettbewerb wird völlig zerstört. Die #Inflation katapultiert auf über 10 %. Die Preise steigen massiv an. Die #Kaufkraft des# Euro lässt massiv nach.
    Die hier entstehenden #Schäden gehen in die #Milliarden, hunderte #Betriebe müssen #schließen, tausende #Leute werden über Nacht #arbeitslos.
    In der Nacht zum 26. September 2022 werden durch gezielte Sabotageakte die Pipelines Nordstream 1 und 2 in der Ostsee zerstört.
    Unsere "Verbündeten" sind heute in der Lage aus dem #Weltall die Marke der Sonnenbrillen von mutmaßlichen Terroristen zu erkennen. Hunderte Drohnen-Videos sind online in denen gezielt Menschen von unserem Land aus beobachtet und getötet werden.
    Hier und heute will man uns weismachen, dass es nicht möglich
    sein soll, die Täter dieser Schweinerei ausfindig zu machen.
    Die #Sabotageakte sind in einer der am besten bewachten Seezonen unseres Planeten passiert. Jede Bewegung der Schifffahrt in der Ostsee wird peinlich präzise beobachtet und dokumentiert. Ankert man mit seinem Segelboot an falscher Stelle, gibt es sofort eine saftige Strafe.
    Sprengt man jedoch 4 Pipelines in die Luft, gibt es nur
    ein laszives Achselzucken. Ungeheuerlich so ein Handeln!
    Und nun will man uns darstellen, dass es nicht nachvollziehbar sein soll, wer zum fraglichen Zeitpunkt vor Ort war, und die Anschläge auf unsere Zivilisation mit den leidigen Auswirkungen ausgeführt hat ?
    Die absolute Spitze der Unverfrorenheit ist die Behauptung, dass die Besitzer der Pipeline diese selbst zerstört haben sollen, obgleich Milliarden an Summen für die Erstellung der Pipelines finanziert wurden und heute noch zur Bezahlung anstehen.
    Sind wir und unsere Gesellschaft wirklich so doof und glauben diesen Unsinn?
    Nach meinem Dafürhalten steht kristallklar fest, wer dafür zur Rechenschaft
    gezogen werden muss und wer uns diesen immensen Schaden zu ersetzen hat !
    Jeder Mensch der sich die folgenden Fragen
    beantwortet, kommt von allein zum Ergebnis
    1. Wer partizipiert daran, dass wir heute kein Gas mehr aus RU bekommen?
    2. Wer verscheuert uns heutzutage sein dreckiges Fracking-Gas?
    3. Wessen Wirtschaft wird durch unsere Produkte gestört und wer hat nun ein Preis-Regulativ?
    4. Wer hat die Inbetriebnahme und den Bau von Anfang an sofort kritisiert und schärfstens verurteilt?
    5. Wer hat bereits im Februar angekündigt es zu verhindern, dass #russisches #Gas durch #Nordstream 2 fließen wird.
    Wenn wir uns diese und viele weiteren Fragen selbst beantworten,
    dann kristallisiert sich der Profiteure an dieser Schweinerei heraus:
    Die Redaktion Infosperber, eine Schweizer Stiftung zur Förderung
    unabhängiger Informationen ( SSUI ) Adresse: Jurablickstrasse 69,
    CH-3095 Spiegel b. Bern schreibt dazu in Ihrem nüchternen Artikel:
    Nord-Stream-Anschlag: «Staatswohl hat Vorrang vor Aufklärung»
    27.10.2022 Die Bundesregierung verweigerte Auskünfte über Positionen
    von Kriegsschiffen. Ihre Stellungnahme liegt jetzt im Wortlaut vor.
    Red. Am 23. Oktober informierte Infosperber darüber: Der Anschlag auf die Nord-Stream-Pipelines bleibt ungeklärt. Auf konkrete Fragen der Bundestagsabgeordneten Sahra Wagenknecht blieben die Ministerien von Habeck und Baerbock Antworten schuldig. In den vollen Wortlaut der Regierungsantworten hatte Infosperber damals keinen Einblick. Unterdessen können wir die Originalfragen und -antworten für die interessierten Leserinnen und Leser wiedergeben.
    Dr. Sahra Wagenknecht
    (DIE LINKE.)
    Welche Maßnahmen hat die Bundesregierung allein, mit EU, anderen Regierungen und der NATO eingeleitet, um festzustellen, wer die Beschädigungen an den Nord-Stream Pipelines verantwortet, und welche Maßnahmen sind geplant, um die Pipelines zu reparieren?
    Antwort des Staatssekretärs Dr. Patrick Graichen vom 11. Oktober 2022
    Bei der Beantwortung der Frage wird davon ausgegangen, dass es sich um die Beschädigungen der Nord-Stream-Pipelines 1 und 2 ab dem 26. September 2022 handelt. Die Bundesregierung und die zuständigen Behörden stehen bezüglich einer Aufklärung dieses Vorfalls in engem Austausch mit Partnern, der Europäischen Union und internationalen Organisationen wie der Nordatlantischen Allianz (NATO). Bisher ist es nicht möglich, Untersuchungen vor Ort anzustellen, deshalb liegen der Bundesregierung auch keine belastbaren Informationen zu den möglichen Urhebern des Angriffs vor.
    Die Bundesregierung steht im Kontakt mit den Projektgesellschaften Nord-Stream AG für die Nord -Stream 1-Pipeline und der Nord-Stream 2 AG für die Nord Stream 2-Pipeline, beide mit Sitz in der Schweiz, zu den Vorfällen ab dem 26. September 2022. Da die Untersuchungen der Vorfälle vor Ort gerade erst beginnen, kann die Bundesregierung zum aktuellen Zeitpunkt keine Aussagen zu Möglichkeiten einer Reparatur geben.
    (DIE LINKE.)
    Welche NATO-Schiffe und Truppenteile befanden sich nach Kenntnis der Bundesregierung seit dem Aussetzen der Gaslieferungen durch die Nord-Stream-1 Pipeline am 30. August 2022 in den Gegenden, an denen die Beschädigungen der beiden Pipelines aufgetreten sind, und welche russischen Schiffe und Truppenteile wurden in diesem Zeitraum in diesen Gegenden geortet?
    Antwort der Staatssekretärin Susanne Baumann vom 11. Oktober 2022
    Die Beantwortung der Fragen zu Schiffspositionen würde Rückschlüsse auf die Aufklärungsfähigkeiten der Bundesrepublik Deutschland und ihrer Bündnispartner zulassen. Die erbetenen Informationen berühren derart besonders schutzbedürftige Geheimhaltungsinteressen, dass das Staatswohl gegenüber dem parlamentarischen Informationsrecht wesentlich überwiegt. Die Frage kann entsprechend aus Gründen des Staatswohls nicht, auch nicht in eingestufter Form, beantwortet werden. Die Beantwortung der Frage würde die Preisgabe von Informationen beinhalten, die das Staatswohl in besonderem Maße berühren. Auch eine Einstufung und Hinterlegung der angefragten Informationen als Verschlusssache beim Deutschen Bundestag würde der Bedeutung der Informationen in Hinblick auf die Sicherheitslage in der Bundesrepublik Deutschland sowie dem Schutz deutscher Interessen im Ausland nicht ausreichend Rechnung tragen. Selbst eine Bekanntgabe gegenüber dem begrenzten Kreis von Empfängern kann dem Schutzbedürfnis nicht hinreichend Rechnung tragen, da auch nur die geringe Gefahr des Bekanntwerdens nicht hingenommen werden kann. Insofern muss ausnahmsweise das Fragerecht der Abgeordneten gegenüber dem Geheimhaltungsinteresse der Bundesregierung zurückstehen.
    (DIE LINKE.)
    Welche Warnungen lagen der Bundesregierung über mögliche Anschläge auf die Nord-Stream-Pipelines vor, und welche Maßnahmen wurden seitens der Bundesregierung auf nationaler und internationaler Ebene ergriffen, um mit der Bedrohung umzugehen (bitte unter Angabe des Datums beantworten)?
    Antwort des Staatssekretärs Dr. Patrick Graichen vom 12. Oktober 2022
    Kritische Infrastrukturen wie die Nord-Stream-Pipelines 1 und 2 unterliegen grundsätzlich einer abstrakten Gefährdung. Die Pipelines sind durch die verantwortlichen Betreiber für im Normalfall auftretende Schäden abgesichert (Verlegung in großer Tiefe, Ummantelung etc.). Mehrere Tausend Kilometer Leitungsstränge können nicht vollumfänglich gegen jegliches Risiko abgesichert werden.
    Darüber hinaus ist die Bundesregierung nach sorgfältiger Abwägung zu dem Schluss gekommen, dass weitere Auskünfte aus Gründen des Staatswohls nicht – auch nicht in eingestufter Form – erteilt werden können. Die erbetenen Auskünfte unterliegen den Restriktionen der «Third Party Rule», die den internationalen Austausch von Informationen der Nachrichtendienste betrifft.
    Die Bedeutung der «Third Party Rule» für die internationale nachrichtendienstliche Zusammenarbeit hat das BVerfG in seinem Beschluss 2 BvE 2/15 vom 13. Oktober 2016 (Rz. 162–166) gewürdigt.
    Lägen solche Informationen vor, wären diese evident geheimhaltungsbedürftig, weil sie sicherheitsrelevante Erkenntnisse beinhalten, die unter der Maßgabe der vertraulichen Behandlung von ausländischen Nachrichtendiensten an die deutschen Nachrichtendienste weitergleitet wurden. Ein Bekanntwerden von Informationen, die nach den Regeln der «Third Party Rule» erlangt wurden, würde als Störung der wechselseitigen Vertrauensgrundlage gewertet werden und hätte eine schwere Beeinträchtigung der Teilhabe der Nachrichtendienste des Bundes am internationalen Erkenntnisaustausch zur Folge. Eine mögliche Kenntnisnahme durch Unbefugte würde erhebliche nachteilige Auswirkungen auf die vertrauensvolle Zusammenarbeit der Nachrichtendienste des Bundes mit ausländischen Nachrichtendiensten haben. Würden in der Konsequenz eines Vertrauensverlustes Informationen von ausländischen Stellen entfallen oder wesentlich zurückgehen, entstünden signifikante Informationslücken mit negativen Folgewirkungen für die Genauigkeit der Abbildung der Sicherheitslage in der Bundesrepublik Deutschland sowie im Hinblick auf den Schutz deutscher Interessen im Ausland. Ein Bekanntwerden der Informationen würde zudem die weitere Aufklärung geheimdienstlicher Aktivitäten in und gegen die Bundesrepublik Deutschland erheblich erschweren. Die erbetenen Informationen berühren somit derart schutzbedürftige Geheimhaltungsinteressen, dass das Staatswohl gegenüber dem parlamentarischen Informationsrecht überwiegt und das Fragerecht der Abgeordneten ausnahmsweise gegenüber dem Geheimhaltungsinteresse der Bundesregierung zurückstehen muss.
    Selbst eine Einstufung als Verschlusssache und Hinterlegung der angefragten Informationen bei der Geheimschutzstelle des Deutschen Bundestages würde im vorliegenden Fall nicht ausreichen, um der besonderen Sensibilität der angeforderten Informationen für die Aufgabenerfüllung der Nachrichtendienste des Bundes ausreichend Rechnung zu tragen.
    Eine unerträgliche Farce ist das und verdichtet die Erkenntnis, dass unser Land, unsere Regierung
    und unsere gesamte Gesellschaft, an den Marionettenfäden der US Amerikaner lanciert wird.
    Saure Grüße,
    Porsche 911 - 964 - 993 - 996 - 997 - 991 - 992 Motorcodes
    911 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    901.01Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis November 1968
    901.02Benzin1991 cm³118 kW / 160 PSJuli 1966 bis November 1968
    901.03Benzin1991 cm³81 kW / 110 PSJuni 1967 bis Februar 1972
    901.05Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis November 1968
    901.06Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis August 1967
    901.07Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis August 1967
    901.08Benzin1991 cm³118 kW / 160 PSJuli 1966 bis November 1968
    901.09Benzin1991 cm³103 kW / 140 PSSeptember 1968 bis Februar 1972
    901.10Benzin1991 cm³125 kW / 170 PSJuli 1966 bis Februar 1972
    901.11Benzin1991 cm³103 kW / 140 PSSeptember 1968 bis Februar 1972
    901.13Benzin1991 cm³81 kW / 110 PSJuni 1967 bis Februar 1972
    901.14Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis August 1967
    901.17Benzin1991 cm³96 kW / 130 PSJanuar 1963 bis August 1967
    911.01Benzin2195 cm³114 kW / 155 PSSeptember 1969 bis Februar 1972
    911.02Benzin2195 cm³132 kW / 180 PSSeptember 1969 bis Februar 1972
    911.03Benzin2195 cm³92 kW / 125 PSJanuar 1970 bis Dezember 1972
    911.04Benzin2195 cm³114 kW / 155 PSSeptember 1969 bis Februar 1972
    911.06Benzin2195 cm³92 kW / 125 PSJanuar 1970 bis Dezember 1972
    911.07Benzin2195 cm³92 kW / 125 PSJanuar 1970 bis Dezember 1972
    911.08Benzin2195 cm³92 kW / 125 PSJanuar 1970 bis Dezember 1972
    911.41Benzin2687 cm³110 kW / 150 PSSeptember 1973 bis August 1975
    911.42Benzin2687 cm³129 kW / 175 PSAugust 1973 bis Januar 1976
    911.43Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.46Benzin2687 cm³110 kW / 150 PSSeptember 1973 bis August 1975
    911.47Benzin2687 cm³129 kW / 175 PSAugust 1973 bis Januar 1976
    911.48Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.52Benzin2687 cm³121 kW / 165 PSAugust 1971 bis Dezember 1973
    911.53Benzin2687 cm³140 kW / 190 PSAugust 1971 bis August 1973
    911.57Benzin2341 cm³96 kW / 130 PSJanuar 1972 bis Dezember 1973
    911.61Benzin2341 cm³103 kW / 140 PSAugust 1971 bis Dezember 1973
    911.62Benzin2341 cm³121 kW / 165 PSAugust 1971 bis Dezember 1973
    911.63Benzin2341 cm³140 kW / 190 PSAugust 1971 bis August 1973
    911.67Benzin2341 cm³96 kW / 130 PSJanuar 1972 bis Dezember 1973
    911.81Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.82Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.83Benzin2687 cm³154 kW / 209 PSAugust 1972 bis Januar 1979
    911.84Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.85Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.86Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.89Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.90Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.91Benzin2341 cm³103 kW / 140 PSAugust 1971 bis August 1973
    911.92Benzin2687 cm³110 kW / 150 PSSeptember 1973 bis August 1975
    911.93Benzin2687 cm³129 kW / 175 PSAugust 1973 bis Januar 1976
    911.94Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    911.96Benzin2341 cm³103 kW / 140 PSAugust 1971 bis Dezember 1973
    911.97Benzin2687 cm³110 kW / 150 PSSeptember 1973 bis August 1975
    911.98Benzin2687 cm³129 kW / 175 PSAugust 1973 bis Januar 1976
    911.99Benzin2687 cm³121 kW / 165 PSSeptember 1975 bis Juni 1977
    930.02Benzin2993 cm³147 kW / 200 PSSeptember 1975 bis Juni 1977
    930.03Benzin2993 cm³132 kW / 180 PSJuli 1977 bis Juni 1980
    930.09Benzin2993 cm³138 kW / 188 PSSeptember 1979 bis Juni 1980
    930.10Benzin2993 cm³150 kW / 205 PSAugust 1980 bis Juli 1983
    930.12Benzin2993 cm³147 kW / 200 PSMärz 1974 bis Oktober 1983
    930.13Benzin2993 cm³138 kW / 188 PSSeptember 1979 bis Juni 1980
    930.19Benzin2993 cm³138 kW / 188 PSSeptember 1979 bis Juni 1980
    930.20Benzin3164 cm³170 kW / 231 PSAugust 1983 bis August 1989
    930.21Benzin3164 cm³152 kW / 207 PSFebruar 1984 bis August 1989
    930.25Benzin3164 cm³160 kW / 218 PSAugust 1986 bis August 1989
    930.26Benzin3164 cm³170 kW / 231 PSAugust 1983 bis August 1989
    930.50Benzin2993 cm³191 kW / 260 PSJanuar 1975 bis Dezember 1977
    930.52Benzin2993 cm³191 kW / 260 PSJanuar 1975 bis Dezember 1977
    930.60Benzin3299 cm³221 kW / 301 PSSeptember 1977 bis November 1990
    930.66Benzin3299 cm³221 kW / 301 PSSeptember 1977 bis November 1990
    964 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    M30.69Benzin3299 cm³235 kW / 320 PSAugust 1990 bis September 1993
    M30.69SBenzin3299 cm³261 kW / 355 PSJuni 1991 bis Dezember 1992
    M64.01Benzin3600 cm³184 kW / 250 PSDezember 1988 bis Mai 1994
    M64.02Benzin3600 cm³184 kW / 250 PSDezember 1988 bis Mai 1994
    M64.03Benzin3600 cm³191 kW / 260 PSJuni 1991 bis September 1993
    M64.50Benzin3600 cm³265 kW / 350 PSJanuar 1993 bis September 1993
    991 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    MA1.03Benzin3800 cm³294 kW / 400 PSDezember 2011 bis ....
    MA1.04Benzin3436 cm³257 kW / 350 PSDezember 2011 bis ....
    MA1.75Benzin3799 cm³350 kW / 475 PSAugust 2013 bis ....
    MAB.03Benzin3800 cm³294 kW / 400 PSDezember 2011 bis ....
    MAB.04Benzin3436 cm³257 kW / 350 PSDezember 2011 bis ....
    993 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    M64.05Benzin3600 cm³200 kW / 272 PSOktober 1993 bis August 1995
    M64.05SBenzin3746 cm³210 kW / 286 PSJuni 1995 bis September 1997
    M64.06Benzin3600 cm³200 kW / 272 PSOktober 1993 bis August 1995
    M64.06SBenzin3746 cm³210 kW / 286 PSJuni 1995 bis September 1997
    M64.07Benzin3600 cm³200 kW / 272 PSOktober 1993 bis August 1995
    M64.08Benzin3600 cm³200 kW / 272 PSOktober 1993 bis August 1995
    M64.20Benzin3800 cm³221 kW / 300 PSJuni 1995 bis September 1997
    M64.21Benzin3600 cm³210 kW / 286 PSJuni 1995 bis September 1997
    M64.21SBenzin3800 cm³221 kW / 300 PSAugust 1995 bis September 1997
    M64.22Benzin3600 cm³210 kW / 286 PSAugust 1995 bis September 1997
    M64.23Benzin3600 cm³210 kW / 286 PSAugust 1995 bis September 1997
    M64.24Benzin3600 cm³210 kW / 286 PSAugust 1995 bis September 1997
    M64.21Benzin3600 cm³210 kW / 286 PSAugust 1995 bis September 1997
    M64.60Benzin3600 cm³300 kW /408 PSMärz 1995 bis September 1997
    M64.60RBenzin3600 cm³316 kW /430 PSMärz 1995 bis September 1997
    M64.60RSBenzin3600 cm³331 kW /460 PSJuni 1997 bis September 1997
    996 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    M96.01Benzin3387 cm³221 kW / 301 PSSeptember 1997 bis September 2001
    M96.02Benzin3387 cm³235 kW / 320 PSFebruar 1998 bis August 2005
    M96.03Benzin3596 cm³235 kW / 320 PSOktober 2001 bis August 2005
    M96.04Benzin3387 cm³221 kW / 301 PSSeptember 1997 bis September 2001
    M96.70Benzin3600 cm³340 kW / 462 PSJuni 200 bis August 2005
    M96.76Benzin3600 cm³265 kW / 360 PSMärz 1999 bis August 2005
    M96.79Benzin3600 cm³280 kW / 381 PSMärz 2003 bis August 2005
    997 Motorcodes:Kraftstoff:Hubraum:Leistung:Bauzeit:
    M96.05Benzin3596 cm³239 kW / 325 PSJuli 2004 bis Dezember 2008
    M97.01Benzin3824 cm³261 kW / 355 PSJuli 2004 bis Dezember 2008
    M97.01SBenzin3824 cm³280 kW / 381 PSAugust 2005 bis Dezember 2008
    M97.70Benzin3600 cm³456 kW / 620 PSMärz 2006 bis Dezember 2012
    M97.70SBenzin3600 cm³390 kW / 530 PSSeptember 2007 bis März 2012
    M97.74Benzin3994 cm³368 kW / 500 PSJuli 2011 bis Dezember 2012
    M97.76Benzin3994 cm³305 kW / 415 PSMai 2006 bis Dezember 2009
    M97.77Benzin3797 cm³320 kW / 435 PSMai 2009 bis Dezember 2011
    M97.77RBenzin3797 cm³331 kW / 450 PSAugust 2009 bis Dezember 2011
    MA1.01Benzin3800 cm³300 kW / 408 PSJuni 2008 bis Dezember 2012
    MA1.02Benzin3614 cm³254 kW / 345 PSJuni 2008 bis Dezember 2012
    MA1.70Benzin3800 cm³368 kW / 500 PSSeptember 2009 bis Dezember 2012
