Technical spezifikations of the Porsche 996 GT3
  • The Technical specifications of the Porsche 996 GT3
    Dear all,
    a customer from abroad asks me about the technical specifications of his 996 GT3.
    Here they are:
    Engine
    Engine Design: 6 cylinder horizontally opposed
    Engine Installation: Rear engined
    Engine Cooling system: Water cooled
    Engine Type: M 96/76
    Engine Displacement (cc): 3600
    Engine Bore and stroke (mm): 100 x 76.4
    Engine Output DIN (kW/Hp): 265/360 at 7200 RPM
    Engine Maximum Torque (Nm/lb ft): 370/273 at 5000 RPM
    Engine Output per litre (kW/l/hp/l): 73,6/100.0
    Engine Compression ratio: 11,7:1
    Valve operation and camshaft drive: Dohc, cams driven by double chain, 4 valves per cylinder,VarioCam, intake camshaft timing varies by 25 degrees
    Engine lubrication: Dry sump system
    Engine Oil Total (l): 12,5
    Injection: Bosch DME, Motronic M 5.5.5, sequential multi-point manifold injection
    Ignition system: Bosch DME, distributorless ignition system with six individual ignition coils
    Firing order: 1-6-2-4-3-5
    Transmission
    Drive configuration: Rear axle drive
    Manual gearbox: 6 speed
    Transmission type: G 96/90
    Transmission Ratios
    1st Gear: 3.82
    2st Gear: 2.15
    3st Gear: 1.56
    4st Gear: 1.21
    5st Gear: 0.97
    6st Gear: 0.83
    Reverse Gear: 2.86
    Final drive ratio: 3.44
    Limited slip differential diff load/deceleration %: 40/60
    Body
    Body design: Steel body, 2 doors, 2 seats, entirely hot dipped gavanised body, side impact protection beams in doors, flexible polyurathane front and rear bumpers with intergrated aluminium beams, front bumper with spoiler, side skirts, engine lid with spoiler lip and fixed rear wing
    Suspension
    Suspension, front: Individually suspended with :disconnected" light alloy wishbones, McPherson struts with coil springs, dual tube gas filled shock absorbers, anti roll bar
    Suspension, rear: Individually suspended on five wishbones per side on light alloy multi wishbone axle with LSA system (Light weight, Stability, Agility), with coil springs, single tube gas filled shock absorbers , anti roll bar
    Front: Spring rate at wheel (N/mm / lbs/in.): 35.0 / 200
    Rear: Spring rate at wheel (N/mm / lbs/in.): 65.0 / 370
    Front: Anti roll bar (tubular- dia x thk (mm)): 26.8 x 4
    Rear: Anti roll bar (tubular- dia x thk (mm)): 20.7 x 2.8
    Brakes
    Brakes, front : Ventilated and drilled discs (330x34)
    Brakes, rear : Ventilated and drilled discs (330x28)
    Brakes, front calipers : Red 4 piston fixed aluminium
    Brakes, rear calipers : Red 4 piston fixed aluminium
    Brakes ABS: Bosch ABS 5.3
    Wheels front : 8j x 18, with 5mm spacer
    Wheels rear : 10j x 18, with 5mm spacer
    Tires front : 225/40 ZR 18
    Tires rear : 285/30 ZR 18
    Electrical System
    Alternator (W/A) : 1680/120
    Battery (V/Ah) : 12/36
    with air conditioning : 12/46
    Dimensions and weight
    Track, front (mm) : 1475
    Track, rear (mm) : 1495
    Wheelbase (mm) : 2350
    Length (mm) : 4430
    Width (mm) : 1765
    Height (mm) : 1270
    Kerb weight (kg) : 1350
    Permissible gross weight (kg) : 1630
    Luggage compartment (VDA(l): 110
    Fuel tank capacity (l): 63 including a 10.0l reserve
    Power to weight ratio (kg/kW/kg/hp): 5.09/3.75
    Fuel consumption :
    Fuel type : 98 RON super plus unleaded
    Urban l/100km: 20,1
    Highway l/100km : 8,9
    Combined l/100km : 12,9
    CO2 (g/km) : 320
    Performance :
    Acceleration 0-100 km/h (s) : 4,8
    Acceleration 0-161 km/h (s) : 10,2
    Maximum speed (mph/kph) : 189/302
    Production totals : 1868
    Best regards
