How to Adjust the Air Bypass Valve on a Porsche 3.2 Carrera Engine
  • How to Adjust the Air Bypass Valve on a Porsche 3.2 Carrera Engine
    On the Porsche 911 Carrera 3.2 (engine types 930/20–930/25, model years 1984–1989),
    idle speed is adjusted via a mechanical air bypass screw on the throttle body. This engine
    does not use an electronic idle control valve.
    Purpose of the Air Bypass Valve
    The bypass valve allows additional air to flow around the closed throttle plate, thereby setting the idle speed.
    Preconditions Before Adjustment
    Correct adjustment is only possible if the following conditions are met:
    1. Engine fully warmed up
      Oil temperature approx. 80–90 °C (175–195 °F)
    2. All electrical loads switched off
      Lights, blower fan, air conditioning off
    3. Ignition timing correctly set
      Approx. 3–5° BTDC at idle (depending on model year)
    4. No vacuum leaks
      Check intake hoses, vacuum lines, and throttle shaft
    5. CO mixture not altered
      CO is adjusted separately at the airflow meter using an exhaust gas analyzer
    Location of the Air Bypass Screw
    • Located on top of the throttle body
    • Slotted screw (sometimes Allen/hex)
    • Easily accessible from above
    Adjustment Procedure (Step by Step)
    1. Start the engine and let it idle (fully warm)
    2. Check idle speed
      • Target value: 800 ± 50 rpm
    3. Adjust the bypass screw
      • Clockwise (in) → less air → idle speed decreases
      • Counterclockwise (out) → more air → idle speed increases
    4. Make adjustments in ¼-turn increments
    5. Wait a few seconds after each adjustment for the idle to stabilize
    6. Set a smooth, stable idle at the specified rpm
    Important Warnings !
    • Do not use the bypass screw to adjust the CO mixture
    • CO adjustment must be done only at the airflow meter and with proper measuring equipment
    • If idle speed barely changes during adjustment, likely causes include:
      • Vacuum leaks
      • Dirty throttle body
      • Faulty idle microswitch
    Common Idle Problems
    • Hunting or surging idle → vacuum leaks or idle switch issues
    • Idle too high even with screw fully in → unmetered air leak
    • Engine stalls → bypass screw too far in or mixture too lean
    Best regards
