991.1 GT3 Cup tuning
  • Hello Sxxxx,
    I currently have several hundred emails to answer, so my reply has unfortunately taken much
    longer than usual. Please accept my apologies for the delay.
    When it comes to your 991.1 GT3 Cup, I see things a little differently compared to a road-going GT3.
    If your car already has:
    • Motorsport ABS
    • An optimized suspension setup
    • Professional data acquisition and analysis
    • Slick tires
    • A well-developed aero package
    and you are already extracting most of the car’s potential as a driver, then an engine upgrade can
    certainly be the next logical step.
    4.0-Liter Cup Engine
    • Approximately 485–520 hp
    • Excellent reliability
    • Most cost-effective solution
    • Full parts support through Albert Motorsport
    For many drivers, this still represents the best balance between performance, durability, and operating costs.
    4.1-Liter Engine
    • Increased mid-range torque
    • Stronger acceleration out of slower corners
    • Approximately 15–25 hp increase
    • No weight penalty
    In my opinion, this is the ideal compromise for ambitious track day and endurance drivers.
    4.3-Liter Engine
    • Significantly more torque
    • Approximately 530–560 hp depending on specification
    • Much more aggressive driving experience
    However, it also places considerably greater stress on the connecting rods, crankshaft assembly,
    and gearbox. Costs are substantially higher, and engine rebuild intervals are generally shorter.
    If the budget allows, this is where I would invest today:
    1. Lithium Battery
      • Approximately 10–15 kg weight reduction
    2. 4.1–4.2 Liter Engine Conversion
    My personal ranking for an ambitious 991.1 GT3 Cup would be:
    1. Driver data analysis
    2. Weight reduction
    3. 4.1-liter engine
    4. Aero fine-tuning
    5. 4.3-liter engine
    The biggest mistake many drivers make is jumping straight to a 4.3-liter engine conversion and then
    running almost identical lap times because there was still significant untapped potential in the
    suspension setup, aerodynamics, or data analysis.
    If your car is already below approximately 1,200 kg including the driver, running quality slick tires,
    and properly set up, I would seriously consider a 4.1–4.3 liter engine conversion. The additional
    torque makes the car significantly faster, especially when accelerating out of slower corners.
    Best regards,
    Albert Motorsport
  • Hello Sxxxx,
    You can also take things one step further and convert the engine to full 4.0-liter GT3 R specification.
    I have all the required components in stock. For this conversion, we would need both the engine and
    the ECU at our facility. We would build and calibrate the engine to maintain a well-balanced and predictable
    power delivery, ensuring the car remains as neutral and drivable as possible.
    The conversion would include, among other components:
    • GT3 R intake system
    • Titanium connecting rods
    • Lightweight high-performance pistons
    • GT3 R cylinder heads
    • GT3 R crankshaft
    • ECU calibration and optimization
    • Various additional GT3 R-specific components
    This conversion represents a significant step forward in terms of performance and overall engine
    specification while maintaining the reliability and drivability required for serious track and endurance use.
    Best regards
