Porsche 993 Upgrade to 993 Turbo - Some questions
  • Dear Mr. Jxxx,
    Thank you for your inquiry.
    The answer depends on your goals, budget, and whether originality is important to you.
    If you are looking for the best performance-to-cost ratio and already own a well-maintained
    993 Carrera, a turbo conversion can be a very exciting project. However, a proper 993 Turbo
    conversion requires much more than simply adding turbochargers. The engine internals,
    fuel system, engine management, cooling, exhaust system, transmission, brakes, and
    suspension should all be considered to achieve reliable performance.
    On the other hand, if you are aiming for factory-engineered performance, collectability, and
    long-term value retention, purchasing an original Porsche 993 Turbo is usually the better
    investment. The factory Turbo offers exceptional engineering, reliability, and market value
    that is difficult to replicate with a converted vehicle.
    To provide a more accurate recommendation, please let us know:
    • Current model (993 Carrera 2, Carrera 4, etc.)
    • Vehicle mileage
    • Intended use (road, track, or both)
    • Desired power output
    • Approximate budget
    Once we have this information, we can advise whether an upgrade or a move to an original
    993 Turbo would be the better solution for you.
    We look forward to hearing from you.
    Best regards,
    Team Albert Motorsport
