Used car test at Albert Motorsport
  • Used car test at Albert Motorsport:
    Would you like to buy a used Porsche?
    Then we go around the vehicle together and
    pay attention to the following points:
    1. Body & Paint
    • Is the vehicle clean?
    • Are waves, dents, scratches or stone chips visible?
    • Are there color differences or dull spots on the paintwork?
    • How big are the gap dimensions? Are they even?
    • Does the vehicle have rusty spots?
    • (Caution! In the event of rust spots, always consult a specialist. Topic: accident damage)
    2. Lighting
    • Examine all lamps.
    • Are the headlights and the rear light working?
    • How is the condition?
    • Are stone chips, cracks or moisture visible?
    3. engine compartment
    • Inspect the engine bay: is this clean and sparkling like new?
    • Note: An engine wash may be a sign that the seller wants to cover up leaks.
    • Check the fluid levels: oil level, cooling water, steering gear, brake fluid,
    • Check the condition of the hoses: are the hoses porous or leaking?
    • Are all clamps on the hoses tight? (Drip liquids?)
    • Pay attention to the toothed belt, if the car have one: Inquire about the toothed belt and get proof of when and by whom it was replaced. In this way you avoid possible engine damage. Now test whether the bonnet closes easily and cleanly.
    4. Interior
    • Doors: Check that all doors open and close easily. Is something stuck or do the doors sag when closing?
    • Are the rubber seals on the doors and hood complete and in good condition?
    • Seats: are the upholstery ok? Does it smell pleasant or rather musty or musty?
    • Are all seat belts functional?
    • Test functions: Start the engine and check the ventilation, the windshield wipers and the functionality of the other buttons, such as the hazard warning lights.
    5. Test drive
    • Try to break your test drive into two parts:
    • One at lower speed and one at higher speed.
    • Drive slowly:
    • Does the transmission shift smoothly and smoothly?
    • Does the car go straight? Can you hear cracking noises when steering?
    • Are the ads working? (Speedometer, tachometer) Do the control lamps go out again?
    • Drive faster:
    • Can you feel vibrations on the steering wheel?
    • Does the car stay on track?
    • Can you hear noises?
    • Does the car brake evenly?
      Caution: Never test brakes on the Autobahn!
    • Air conditioning: does the air conditioning and heating work?
    • Is the ventilation ok?
    6. Underbody
    • Defects are best recognized after the test drive
    • Condition of the engine: is there oil dripping?
    • What does the exhaust system look like? This is where the most common shortcomings hide.
    • Are the brake pads OK?
    • Is there sufficient document strength?
    • Are the brake discs worn or rusted?
    • Is the brake caliper stiff? You can tell by the still rusted brake discs.
    • Do the tires have enough profile?
    • Are the tires worn evenly? (Note on toe and camber settings)
    • Can you see any damage on the tire sidewall or in the tire profile?
    • Are the rim edges damaged?
    7. Vehicle Papers
    • Look at the vehicle papers: Are the papers complete?
    • Are the instructions for use available?
    • Are the owner and seller the same?
    • Is there a maintenance booklet?
    • Were the entries created?
    • First aid kit and warning triangle: do you have both?
    • Is there also a safety vest on board?
    • What is the condition of these things? ( Note the expiry date )
    The Albert Motorsport 120+ points check
    1. daytime running lights
    2. dimmed headlights
    3. high beam
    4. parking lights
    5. indicator
    6. fog lights
    7. license plate light
    8. rear lights
    9. reversing lights
    10. brake-lights
    11. Hazard warning lights front and rear
    12. rear fog light
    13. Door contact / interior lighting
    14. Control panel status
    15. Instrument lighting controller function
    16. Warning light/sound
    17. light warning
    18. Warning light/sound open door/open hatch
    19. Oil pressure warning light/sound
    20. Engine electronics warning light/sound
    21. Warning light/sound ABS/ASR/ESP
    22. Brake system indicator light
    23. Shift control indicator light / shift indicator
    24. turn signal indicator lights
    25. High beam indicator
    26. Low beam indicator light
    27. Functional check of headlight cleaning
    28. Visual check of airbag system
    29. Functional test radio
    30. Functional test of the horn
    31. Functional check clock
    32. Functional test of the cigarette lighter
    33. Functional test of rear window heating
    34. Control heating / air conditioning
    35. Functional test of interior lighting front/rear
    36. Functional test CD player / CD changer
    37. Electrical mirror adjustment
    38. Heated rearmirros
    39. Condition selector/shift lever
    40. Functional test windscreen cleaning
    41. Headlight adjustment
    42. Fog light adjustment
    43. Battery function/condition/battery voltage
    44. Condition front / rear seats
    45. Longitudinal adjustment of driver's/front passenger's seat
    46. Seat height adjustment for the driver's seat and, if necessary, the passenger's seat
    47. Lumbar support adjustment for driver's seat and possibly front passenger's seat
    48. Front/rear headrest adjustment
    49. Front seat heating function rear seats
    50. Front/rear seat belt function
    51. Locking doors / trunk
    52. Functional check of anti-theft system
    53. Electric windows
    54. Trunk/tank release
    55. Glove box lock
    56. Glove compartment lighting
    57. Functional test sunroof
    58. Condition armrests - door handles - door panels
    59. Condition door entry / sill strips
    60. Key set complete
    61. Condition of headliner / sun visors
    62. Lighting mirror sun visor
    63. Condition carpet floor mats - used
    64. Condition luggage net luggage compartment partition
    65. First aid bag according to StVZO
    66. Functional test of radio remote unlocking
    67. Condition of the body parts
    68. Alignment / Condition of the bumper Paintwork condition
    69. Condition windshield window guides
    70. Spare wheel incl. jack available, tire repair kit if necessary
    71. On-board tool wheel lock according to wheel size
    72. Tire type / correct tire size Condition of the rim
    73. condition of the brake discs
    74. Condition of brake pads
    75. Condition of brake hoses lines connections
    76. Condition spars cross member underbody
    77. Condition of chassis subframe
    78. Tightness engine mounts / oil pan - condition / engine leaking at the chain case
    79. Tightness of fuel lines
    80. tank
    81. Condition of tie rods
    82. Condition - function steering gear
    83. Condition ball heads
    84. Condition exhaust system including catalytic converter
    85. Condition of hoses / dirt sheathing
    86. Steering wheel rest position - slightly oblique?
    87. Chassis number available
    88. brake fluid level
    89. Engine oil level
    90. power steering oil level
    91. Steering leaking
    92. coolant level
    93. antifreeze
    94. washing water
    95. washer fluid level
    96. condition cable straps
    97. Starting behavior of the engine
    98. Engine idling behavior
    99. engine behavior while driving
    100. Functional test speedometer - if necessary. GPS measurement
    101. Functional check of the tachometer
    102. Functional test kilometers
    103. Functional test of trip meter
    104. Functional test of cruise control system
    105. Proper driving noise
    106. Functional test motor fan
    107. switching points and switching paths
    108. Automatic Tiptronic mode
    109. Function of the displays while driving
    110. steering behavior
    111. straight running
    112. Unusual resonance vibrations
    113. garage door opener
    114. cool box, if available
    115. Electric steering wheel adjustment
    116. Functional test of the navigation system
    117. DVD for navigation available?
    118. Functional test car telephone functional test
    119. Bluetooth and mobile phone preparation
    120. Seat memory function
    121. Electric tailgate
    122. Electric sun blind
    123. Seat air conditioning / massage function seats
    124. parking assistance
    125. Tire pressure control system
    126. Auxiliary heating, if present
    Albert Motorsport also carries out used car checks!
    Important for the purchase of Porsche 996 - 997 - 991 - Boxster - Cayman:
    In any case, have an engine endoscopy of the cylinders carried out.
    Very many customers would have, to put it sportily, "wet the toilet".
    and bought a car with engine failure starting, we would have these
    The cylinders were "NOT" checked in advance.
    If you have any questions, please do not hesitate to contact me.
    Warm greetings
    master mechanic
